10K Grease fitting
Results 1 to 6 of 6
    Nov 2017
    New York
    20
    12
    Default 10K Grease fitting
    Browsing the book on SB rebuild, I came across the picture of a grease fitting that fits my spindle and back shaft, Thing is it's a 1/4-20 thread. I can find 1/4-28 fitting or 1/2-20 fitting, nothing in 1/4-20. I am using a chainsaw bar greaser to inject grease into these two shafts, my imagination and creativity must be stunted, what are you guys using to grease your SB?
    Jan 2019
    North Carolina
    177
    26
    23
    While I haven’t done this for a lathe, I’ve always found that if you can’t find it, make it is the proper method. Cut some 1/4-20 threads on a round bar and tap the other side for a grease fitting thread that you can find. Bore thru and screw together and bam, pump her full of lube.
    Mar 2012
    Geilenkirchen, Germany
    2,308
    1394
    1190
    Quote Originally Posted by gjkozy View Post
    Grease? SB 10K? Just where do you grease? I own a 10K since 1980 and I never use grease, only oil.
  4. Likes 10KPete liked this post
    Jan 2019
    North Carolina
    177
    26
    23
    Quote Originally Posted by steve-l View Post
    In the cone pulley where you lubricate the bearings. I'm pretty sure older machines had "Grease" stamped above this lube port while newer machines were marked for oil. Also I'm pretty sure there's a grease port on my eccentric shaft on my 13" South Bend.
    Sep 2010
    moscow,ohio
    5,905
    579
    1889
    Feb 2015
    Florida
    320
    56
    Quote Originally Posted by naru View Post
    It is the other way around. The older machines have "OIL" for Type C oil and the newer machines have "GREASE" for the teflon grease. The only other place for grease would be the motor bearings IF it had a grease zerk.
  8. Likes comstockfriend, 4GSR liked this post
