piniongear
Stainless
- Jun 26, 2006
- Canyon Lake Texas
Recently I have used the lathe to cut threads, turn pieces etc and it has worked fine, as usual.
This morning I was oiling the mill and the lathe as I do from time to time.
I turned on the lathe with the lead screw engaged to run in the oil that I placed in the oil cups.
Immediately the gearbox started making a clunking noise like two (or more?) gears were not engaging.
It does this in forward and in reverse, as well as setting the gear change levers to different positions.
Does anyone have an idea what has gone wrong?
The machine is a 10K Model A tool room lathe.
Honestly, all I did was drop some oil in the cups and turn on the lathe.
I do not know where to begin, so any help or comments are more than welcome.
pg
pg
