Is this a 10K steadyrest?
Likes Likes:  0
Results 1 to 9 of 9
    Feb 2004
    Carver, MA
    709
    Default Is this a 10K steadyrest?
    I recently acquired a large lot of lathe tooling, which included this steadyrest. It measures 5" from the flat way surface to the center. I identified it as SB 10K, listed it on Ebay and sold it. Buyer said it wasn't for a 10" lathe. Huh? Come to find out he had a 10L and a Logan 10", said it wouldn't fit either of them, shocker. Just like to confrm it is 10K before I try selling it again.
    Thank you very much, Jim Bishop
    Attached Thumbnails Attached Thumbnails 20190514_131650_resized.jpg   20190514_131717_resized.jpg   20190514_131623_resized.jpg   20190523_130630_resized.jpg   20190523_130650_resized.jpg
    May 2012
    Pittsford, NY
    1,040
    717
    668
    Doesn't look like my 10K steady. Mine has the knob adjustments with round fingers.
    Sep 2010
    moscow,ohio
    5,952
    580
    1901
    Upon confirmation I may like to purchase it.
    can you take an exact measure from the notch of the v way to the center of the flat way...from here it looks about 3.5" or so?
    And is it truly 5" from flat to the split?
    Feb 2004
    Carver, MA
    709
    Quote Originally Posted by iwananew10K View Post
    Well shame on me, paying a little more attention, it actually measure 4-5/8" from the flat to the split. Center of the vee to the center of the flat is 3". Just noticed the top casting is stamped 126NR1 and the bottom casting is stamped 125N1. With this info, more likely it is for a SB 9"?
    Jan 2014
    Coventry RI
    1,146
    1379
    913
    If iwananew10k passes, I'd be interested in buying it.
    Sep 2010
    moscow,ohio
    5,952
    580
    1901
    ??? Are my eyes fooling me? Center of v to center of flat looks about 3.5" on my screen....certainly more than 3"?
    hold while i consult the oracle on the casting numbers.
    Jul 2004
    Houston, TX USA
    30,074
    Regular not made for light ten. Telescoping only
    Feb 2004
    Carver, MA
    709
    Weird, took another pic, that is also deceiving. I can assure you the "1" on the tape is aligned with the center of the vee, and the "4" is centered in the middle of the flat.
    Sep 2010
    moscow,ohio
    5,952
    580
    1901
    3" would make it for a 9" workshop series....darn 5/8" more and I'd be all over it.
    Pass to Derek.
