10k vs 10L tail stock
Likes Likes:  0
Results 1 to 14 of 14
    Apr 2020
    Michigan
    49
    Default 10k vs 10L tail stock
    First of all thank you for all the response and support. I’m restoring as it turns out is a SB 10L (please see my other threads) turns out after beautifully restoring the tail stock it’s for a 9. Aaaaarrrg, getting frustrated. Need a new tail stock. Is there a difference between the tens? Is a 10L tail stock different than a 10k? Help please!!!
    Jan 2014
    North Carolina
    507
    19
    152
    Yes there is a significant difference between the two of them. The 10L bed is much wider than the 10K bed so there is no way a 10K tailstock can fit on a 10L bed.
    Apr 2020
    Michigan
    49
    Can I just replace the upper portion. The base plate seems to fit just fine. See pic
    Jul 2004
    Houston, TX USA
    30,903
    Second photo in Post #3 is not a 10L, it is a 10K - and the 9 tail stock fits but is of course too low - as the second photo shows
    The heavy 10 - like 10L - is a larger heftier lathe compared to 9 / 10K
    Apr 2020
    Michigan
    49
    Look at the headstock there is a small hole for what should be a counter shaft. If you look at an old SB catalog it lists as a 10L, even my model number matches the catalog
    Feb 2015
    Florida
    715
    193
    Quote Originally Posted by mwill135 View Post
    You look again... the catalog number you gave was a 10K model number, not 10L. A CL770 is the model number for a 10K.
    Jul 2004
    Houston, TX USA
    30,903
    Early on you showed us a photo with CL770 Z stamped on the red "tag" on the QC gear box
    You will find 770 Z in this LIGHT 10 catalog on Page 6. Another name for the same lathe you have used frequently in your posts is 10K
    http://www.wswells.com/data/catalog/...alog_L-10E.pdf
    ph
    Apr 2020
    Michigan
    49
    Yep I was misspoken as the pic below will show it’s a 10L. So what are my options for a tail stock? Can I use any part of mine?
    Sep 2010
    moscow,ohio
    6,348
    647
    2111
    short answer is no.
    could you make it work? yes...but you will be ahead of the game to source one from a 10K and sell the one you have.
    Jul 2010
    Virginia, USA
    3,530
    87
    677
    Your lathe is a 10K, based on that headstock...
  11. #11
    Jan 2017
    Massachusetts
    237
    43
    What you have there is a 9" tail stock on a 10K lathe.
    Here is a couple of pictures of an extra 9" tail stock I have, set on my 10K bed. 10K tail stock is also shown.
  12. #12
    Apr 2020
    Michigan
    49
    What is the Morse taper on the 10k tail stock
  13. #13
    Feb 2015
    Florida
    715
    193
    MT2 for the tail stock taper.
  14. #14
    Sep 2015
    Florida
    701
    5
    105
    Easy-peasy fix...
    Just make a 1/2" adapter plate for the base. This will get your center height to the correct 5".
    Almost did something similar with a 1" plate to get an extra 9A tailstock to fit my 11" Sheldon (before I was finally able to locate a correct one).
