10L carriage Lock screw and plate
Results 1 to 6 of 6
    Aug 2015
    North Carolina
    13
    Default 10L carriage Lock screw and plate
    The new heavy 10 I bought does not have a carriage lock screw or plate. I have found several 9 and 10k and 14-1/2" + screws.....but the 10L doesn't seem to be as readily available.
    Does anyone have a source for them, have one sitting around, or have a good print for them?
    Feb 2015
    Florida
    529
    115
    Because we can't attach .pdf files over ~75k, here is a picture of a pdf file of an H10 carriage lock (the original was made out of cast iron).
  3. Likes Yan Wo, swells liked this post
    Feb 2004
    peekskill, NY
    24,687
    4717
    I don't know why those square head bolts are always missing from those lathes.
    I finally made a form tool to machine the top, before milling it square, for one of
    my lathes.
    Mar 2020
    New Hampshire
    11
    Is it possible to replace the bolt with out removing the saddle from the lathe? At some point the square head bolt was removed and replaced with a hex head bolt. I'd like to make a replacement bolt for it but I'm not willing to remove the saddle just to replace the bolt.
    Feb 2004
    peekskill, NY
    24,687
    4717
    Quote Originally Posted by ctjctj View Post
    Yes. I think even the lock plate comes out the side, but it can stay in place if you are only changing the
    bolt.
  7. Likes ctjctj liked this post
  8. #6
    Sep 2010
    moscow,ohio
    6,068
    591
    1962
    to save yourself a litte grief before you remove the bolt to replace it
    slather a little high tack grease or some such to the bed/lock junction.
    tighten old bolt, let the lock "stick" to the bed.
    then genttly remove the old and replace with new.
  9. Likes ctjctj liked this post
