10L Clutch Sleeve Lock Ring Removal
Chas2
Sep 5, 2019
I have a dirty 10L that needs cleaned. I have run into a problem in removing the clutch sleeve lock ring. Can anyone identify a brand of external lock ring pliers that can be used to successfully remove the clutch sleeve lock ring? Or does anyone have a technique that can be used to remove this lock ring.
Thank you for your help in this matter.
Chas, take a pair of no-brand needle nose pliers, grind the tips flat evenly on both sides until they slip between the ring ends.
Expand and remove, install the same way.
Steve
