10L Clutch Sleeve Lock Ring Removal
Likes Likes:  0
Results 1 to 2 of 2
    Sep 2019
    Default 10L Clutch Sleeve Lock Ring Removal
    I have a dirty 10L that needs cleaned. I have run into a problem in removing the clutch sleeve lock ring. Can anyone identify a brand of external lock ring pliers that can be used to successfully remove the clutch sleeve lock ring? Or does anyone have a technique that can be used to remove this lock ring.
    Thank you for your help in this matter.
    Dec 2004
    Indiana
    1,586
    380
    142
    Chas, take a pair of no-brand needle nose pliers, grind the tips flat evenly on both sides until they slip between the ring ends.
    Expand and remove, install the same way.
    Steve
