ronlyke
Cast Iron
- Aug 24, 2008
- Queensbury, NY
I have a 10L with taper attachment (telescoping cross slide screw). The nut at the rear end of the cross slide screw (behind the taper attachment) has me puzzled. When I tighten it, it prevents the screw from turning. When I loosen it a little and retract the cross slide, I get a corresponding increase in backlash, and as I advance the cross slide, the nut will tighten on its own eventually binding the screw again. I suppose I could use a Nylock nut, or Loctite, and locate the nut where it does the most good and least hassle, but I don't think that's original. Can someone advise me of the correct way to do this?
