ChipBed - that is nearly exactly the way I had
set up my original 10L, which like yours had
the cast iron pedestal base, and the cast iron
legs at the outboard end of the bed. I also
used some composite rubber/aluminum anti-vibration
mounts, two under the motor pedestal, and one
at each leg. In my case I was bolting the
shims (I think they ranged from 30 down to
beer-can size...) between the leg and the pad.
This worked great and was the only thing I had
to do to get the machine to turn as well as it
did. It was a badly, badly worn old machine but
was great for what it could do. Because the
bed was worn I could not get it in to better
than a thou of accuracy within six or so inches
near the headstock - this using the two-collar
method.
Webb - of course you are correct. A used machine
can have had all *kinds* of abuse heaped upon it
and your caveat is well taken. Even so, all
the complete machines I've ever purchased are
taken apart for cleaning and a quick look-see.
All of the lathes have had the original hand
scraping visible on the bed under the headstock,
and the headstocks are fitted to the bed without
any interference from dirt, etc. which would
skew them off axis.
Your point is so important and vital, it bears
re-iterating in a stronger fashion so I would
do that if you don't mind:
I would personally *not* purchase any lathe that
has had the manufacturer's original fitment of
the headstock to the bed altered or destroyed.
Once this occurs the machine is badly compromised
and will probably never be accurate enough to
turn to better than a thousanth, over any length
along the bed.
If a machine were presented to me in that fashion,
the thoughts that would run through my mind would
be, "parts machine," or "hand scraping exercise,"
or maybe "scrap metal."
There are enough used, good condition machines
available that a machine with the headstock
tweaked up would have to be a) nearly free, b)
close by to inspect, or c) some unusual, vintage
lathe desirable as an antique. But *not* a
runner.
Jim
