10R tail stock question
Likes Likes:  0
Results 1 to 5 of 5
    Nov 2018
    CANADA
    Manitoba
    10
    Default 10R tail stock question
    Hi everyone, I am starting to tear down my new acquisition, winter is setting in here and its quality time in my shop now until spring. I figured I will start with the tail stock, teardown, inspect, repair if needed and then onto the next piece. Here is what I found so far, I am guessing this is a sign of a bigger problem. I will grind those welds off and see - who would weld on something like this - crazy.
    Also, I assume that I should put some heat to that knurled nut, and that its a right hand thread? I tried budging it and its not moving.
    Thanks, last picture is one of the lathe, took the end one pedestal cover off to strip down
    Attached Thumbnails Attached Thumbnails img_5955.jpg   img_5954.jpg   img_5956.jpg   img_5951.jpg
    Sep 2010
    moscow,ohio
    5,904
    579
    1887
    Looks like someone shimmed up a worn tailstock and then welded it into "alignment"...
    Now,that's a *real* bodge!! LOL
    FWIW- should be fixable I think.
    Nov 2017
    234
    146
    146
    Count yourself lucky they did such a discrete job of tacking it. Could be MUCH worse. A strap wrench is the right tool for that nut, a little heat prior couldn't hurt.
    Aug 2014
    bainbridge island
    1,129
    213
    267
    my guess is the headstock and the tailstock are from a different lathe. as to why the tailstock is welded, no idea.
    heat the casting not the nut to get that the tailstock apart.
    Nov 2018
    CANADA
    Manitoba
    10
    Yes, I should have checked my sentence, I intend to put some heat to the casting, no need to make that nut expand while I am trying to get it to turn out
