Hi,
I have an 11"X 3' lathe Cat # 484YN serial # 46256. I don't use it much except for threading. I was trying to cut a 26 tip thread but for some reason when the lever is in the left position it will not engage the lead screw. It will engage when it is in the center and right position. The last time I used it to cut a thread in this range it worked. I have attached a picture of the quick change gears with the lever to the left. Does anyone have an idea why I can't gt the lead screw to engage? Thank you for any help. Don
