dwall174
- Sep 14, 2011
- Southeast MI.
I recently picked up a 13" SB Turret lathe that has the 3-step cone pulley set-up.
The previous owner changed the v-belts & pulleys to apparently make run it faster than normal?
I want to try to get it back to as close to the original speeds as possible.
According to several manuals I've checked the motor pully should be 2-17/32", But I haven't seen anything on the original size for the large v-groove drive pulley.
Does anyone know what the size of the large V-groove drive pulley is on the 3-cone pulley set-up?
I'm pretty sure it's the same as the 4-cone pulley models, but it could be a little different because of it being a turret lathe?
Doug
Doug
