Good evening. I recently inherited my father's 1943 13" SB lathe. It was in his shop for about 40 years and I'm now looking forward to getting it cleaned up and having it in my shop. I've found that the 80t idler on the gear change set has a broken tooth. The gears are 16dp and 14.5pa. Martin Sprocket stocks a 80t spur gear I could bore and bush, but they are only 1/2" on the face while the SB is 5/8. Any thoughts on whether that would be a problem?
Any one know of an 80t gear looking for a home or have any other suggestions?
Thanks!
Thanks!
