Hoping someone can confirm what I have tried to ascertain.
I have a 13" with the single tumbler quick change gearbox. I am in the process of refurbishing the lathe.
I struggled to get the gearbox disassembled. On the code shaft, there is a taper pin that holds a nut on one side of the shaft. I tried for 3 days to get that pin out. I resorted to drilling it out. I was fortunate enough that my drill ran nearly perfectly down the center of the pin. I was able to use a screw extractor get it free.
Unfortunately, it also broke in half and is a little buggered up.
Can anyone, with certainty (I can guess, too) if the size of that pin matches this:
McMaster-Carr
1.25" in length, 0.156 large end, 0.13 small end, rate of taper 1/4" per 12"
It's what I was able to measure with my calipers. But the ends were filed flush before I was able to get it out.
And would I want stainless or carbon steel?
Thanks in advance.
McMaster-Carr
Thanks in advance.
