16" SB 48 tooth Spur Gear
Results 1 to 7 of 7
    Nov 2005
    North Carolina
    35
    Default 16" SB 48 tooth Spur Gear
    Need a 48 tooth spur gear (Part Number PT612K48FH4) for my 16" SB lathe. Does anyone have one for sale or better yet have the dimensions (OD and DP) so that I can make one? This gear is needed to thread coarse threads. Thanks in advance for any assistance.
    Feb 2016
    1,609
    1080
    578
    I would post pics and location of the gear. Most won't know or look up part numbers.
    Nov 2005
    North Carolina
    35
    The gear I'm looking for is part 106 on the attached picture.sb_form909d_1_-custom-1-.jpg
    Apr 2016
    280
    124
    107
    you should be able to work out OD and DP from the 24t (?) stud gear that's on there. DP = (no. teeth + 2)/ OD. So for my SB9, 48t stud gear is 2.775", so DP = (48+2)/ 2.775 = 18.
    Once you've figured out DP, then OD = (no. teeth + 2)/ DP. So for a 24t gear for my lathe, that would be (24+2)/18 = 1.444".
    The other critical dims are width of gear, bore diameter and key way width. You might get lucky and find a close enough equivalent from Boston Gear or ebay - say one that needs boring out (or sleeving) to fit.
    Sep 2012
    Cincinnati
    362
    13
    81
    Well no idea where it came from, but I have a spare. Looks to be in reasonable shape. I don't need a spare for this gear...........
    PM me and lets see if we can work something out.
    Feb 2016
    1,609
    1080
    578
    Quote Originally Posted by Robert Lark View Post
    That's the stud gear off reverse tumbler. The one I have mounted is 18 tooth.
    Jul 2004
    Houston, TX USA
    31,713
    The 48 tooth for the double tumbler. Note it says 4 1/8 dia, which works out to 12 DP. (actual O.D. will be nearer 4.16)
    South Bend 16" Lathe Banjo Bracket 48 Tooth Gear (Dual Tumbler Gear Box Only) | eBay
    have fun
    You could see if your 24 is 2.166" OD
    You can plainly see here 24 and 48 tooth stud gears are used
  8. Likes texasgunsmith liked this post
