got this about 12 years about been covered up outside traded for a ruger single six 22 pistol that went though the ceder fire that was resurrected should have taken some before pic's
a few more pic someone had drilled the back gear cover to mount the drum and start stop mag starter switches it wobbled around like a pea in a wash tub and being i was replacing the org 3 ph. motor with a single ph. i went with just the drum switch so i came up with this mounting pad using the two holes that were there and the collet closer bracket hole and being i have an extra head stock i used it as a fixture to hold things as i did the machine work one thing for sure it ain't going to wobble no more
gone about as far as i want to on this one the work lamp is from an old safety clean wash tank made a bracket that bolts to were the tapper attachment would go chuck is a btc off an old crank grinder back plate is one that i turned around [thanks mr. pete on you tube] so the true adjust [sorry buck] would work after i sleeved it so other that that that's about all thanks for looking
man Hell of a job!, Pics like these make me wish i would has spent more time on the cosmetics getting mine back in shape! Was just to anxious to turning and make perfectly good metal stock into junk parts! as This old TOny would Say!
