30tpi, SB 9A
Results 1 to 4 of 4
Thread: 30tpi, SB 9A
    Feb 2018
    Iowa
    33
    6
    Default 30tpi, SB 9A
    Hi folks,
    Am I thinking correctly if I switch out the 56 tooth screw gear with a 42 tooth gear and set the qcgb at 40 ... will I end up with 30 tpi ? Or is there a better way?
    May 2014
    Ohio
    41
    21
    Confirmed that it worked perfectly on my Heavy 10 swapping the 56 tooth on the gearbox input for a 42 tooth.
    Hope this helps.
    Ben
  3. Likes 500mpxlcameraguy liked this post
    Jul 2004
    Houston, TX USA
    31,963
    Or.....42/56 = .75 and 40 times .75 = 30
  5. Likes 500mpxlcameraguy liked this post
  6. #4
    Feb 2018
    Iowa
    33
    6
    Thanks to both of you for the confirmation. Much appreciated.
