Rob_Toronto
- Dec 11, 2019
Hello, I'm new to the site, I recently bought a disassembled heavy 10L and I'm in the process of gathering missing parts to assemble it. The only reason I bothered with this is because the previous owner had the bed milled and the saddle fitted with turcite. Apron, headstock, and tailstock were worked on and everything looks really good, no play whatsoever in the tailstock, etc. However, no tooling, no change gears, and a few other small things. (This is one of the models without QC gearbox) My question is regarding a chuck. There's a brand new 8" TOS chuck at work that I can have for free, but I'm concerned it's too heavy for the lathe. I'd use the 8" just to get going before I eventually get a smaller one, so I'm not asking if it's an appropriate chuck, I'm more concerned about actually overloading the headstock bearings etc. By the time I make a backplate and mount the chuck, will it be too heavy? Too much overhang? Or can I use that setup to get going just to take some test cuts, fool around with it, and make sure everything works the way I want before I spend more money on a proper size chuck? For reference the 8" chuck weighs about 30 lbs, and I guess the backplate would weigh 8-10 lbs. If anyone could share similar experiences or opinions it would be appreciated. Also if anyone has spare parts they'd be interested in selling I'd be interested in that too, Specifically tooling, steady rest, gears etc.
Thanks!
Thanks!
