9" Cat# 344 Steady
animal12
Stainless
Apr 9, 2009
CA USA
I have a bud that has a super clean 9" cat # 344 lathe & the steady he has seems to bet a bit off for his lathe . I'll try to attach some pics & see what you folks think . P1020709.jpgP1020710.jpgP1020711.jpg
thanks
animal
The 9, 10k and 10L all used the same upper casting, PT116NR1 in this case. I could not read the base casting number which will ID which of the three it fits. There should be a unit code stamped on the bottom surface next to the V groove that will ID the model of lathe it fits as well, I am guessing SR-101*. The * will give you the model, N for 9”, K for 10k and R for 10L if I remember correctly.
Hope this helps
Ben
Ok thanks . I'll try to get over there tomorrow & get that # , & just for kicks I'll take mine over ( I have a 9A )& see it it fits .
thanks
animal
