mcload
Hot Rolled
- Nov 5, 2007
- Houston, Texas
Hello crew; I hope all are well.
I decided to start the disassembly of my 1959 9" Model B for lack of anything else interesting to do. Not much to report. Had to use a propane torch to get the two taper pins out of the apron assembly, and I managed to twist off two of the #8-32 screws holding the thin plate for the reservoir...lucky me...thank you very much.
This lathe came with a bunch of change gears, naturally, and I thought I might head down that road of identifying them.
When looking in the HTRL manual, they have the gears listed in figure 210, page 73 of my handbook (Vol One; Edition 43).
The heading of the list reads 10" Series S Standard Change Gear Lathe. So my first question is: are the gear numbers the same for a 9" and 10" lathe? I would assume so, except 10" only wider.
Would a standard set of gears that came with a 9" Model B include ALL gears on the list (#4 thru #160)? I'm guessing probably not as that's quite a lot of gears. Maybe just a general range?
Are there any other SB publications I can refer to on this topic?
Was there an owners manual specifically for the 9" ModelB?
Many Thanks!
PMc
View attachment 292918 View attachment 292919 View attachment 292920
Many Thanks!
PMc
