mcload
Hot Rolled
- Nov 5, 2007
- Houston, Texas
Hello and thank you in advance. I realize that this is probably a very dumb question, but thought I'd ask anyway.
While looking at the Baldor (replacement) motor on my little 9", I couldn't help but notice what a mess it was:
wood dust in the fan intake and oil slung all over it. And additionally, how much room it takes up between the bed
and motor mount. I DO realize that I could make a motor shield to cover it.
But with that being said, has anyone tried to mount the motor on the backside of the mounting frame? I realize that the
motor weight aids with forward tilt to disengage drive belt, but is this forward weight necessary? I'm just wondering if
anyone has moved the motor to allow more room and keep cleanup easier. Although the motor is not all that noisey, there
is a pretty good hum coming off of it. I rarely change the position of the motor drive belt on the pulleys. I do realize I'd
need a smaller belt. But doing this would put the motor electrical box out of the way as well as the ugly armored cable,
which I plan to get rid of.
There's probably a good reason NOT to do this, but I don't know why. (I am currently doing a maintenance cleanup and paint
job, and plan to relocate the drum switch down to the front of the machine).
Thank for input!
Thank for input!
