Is it cast iron or cast steel? The reason I ask is the lever/handle is broke off mine. I bought a handle/cam, shaft and eccentric on e bay thinking I'd swap out the handle end but the pin is in a different location. I installed all three pieces and now it's noisy with the back gear engaged. If it's cast steel I'll make a handle and tig weld it to my broken piece. If it's cast iron I may try silicon bronze or aluminum bronze.
Thanks, Justin
Thanks, Justin
