question for the pro's here . what is the best way to check headstock alignment after HS removal ? I seem to be cutting a slight taper when turning with a chuck on the HS.I was thinkin of using a length of 3/4" drill rod in the chuck if it will fit through the HS & then run a dial indicator up & down the bed till I'm happy with it . Should the HS just drop in place & get tightened down ? Am I headin in the right direction here ?
tks
animal
tks
animal
