9A Spindle drawing
Likes Likes:  0
Results 1 to 10 of 10
    Apr 2009
    CA USA
    106
    10
    Default 9A Spindle drawing
    I'm sure I have seen a drawing somewhere of a 9A spindle with dimensions , but I have been unable to find it again . any of ya folks know where there might be such drawing ?
    tks
    animal
    Sep 2004
    Fort Worth, Texas
    2,182
    295
    194
    I save every such file I have ever run across, and I don't find that one.
    Jan 2014
    Utah
    600
    1494
    256
    What accuracy do you need?
    Apr 2009
    CA USA
    106
    10
    My 9A has a very small step on the spindle where the chuck bottoms out , I was wonderin if that's right for this lathe ? I've been chasin a chatter problem & noticed what looked like a gap between the back of the chuck & the mating surface of the spindle , some folks call this the register. I can get a .008 feeler gage behind the chuck & the spindle but not all the ways down to the diameter of the spindle . does that make sense? I will try to make a drawing tomorrow & post it . my chatter prod only happens while turning steel , I don't remember if what I am using is CR or HRS , but it looks like hell . I can turn aluminum & get a mirror finish all day long . I just did a spindle check & i have .002 in spindle movement . the left side bearing seems to run @ 20 deg warmer than the chuck side , perhaps I have the thrust nut too tight ?I am usin AR Warner HSS cutters & home ground HSS . I tried all 3 speeds plus backgear . my work piece is @ 1.2" dia right now , but gettin close to finished size so I stopped workin on it till I get this figured out
    tks
    animal
    Sep 2010
    moscow,ohio
    6,075
    592
    1965
    heres a pic of a normal looking spindle..that ring around the bearing is actually a separate part amd just presses on there.
    is that what your referring to?
    https://www.recycled-parts.com/Curbs...ly-photo-2.jpg
    Apr 2009
    CA USA
    106
    10
    yea , that's it . what is its purpose ? I wasn't sure if someone had done some sort of mod to the spindle
    tks
    animal
    Sep 2010
    moscow,ohio
    6,075
    592
    1965
    its just to help keep chips out of the headstock.
    Apr 2009
    CA USA
    106
    10
    ok so the larger siameter part is the pressed on part & the part that the chuck backs up to is the actual spindle ?
    animal
    Sep 2010
    moscow,ohio
    6,075
    592
    1965
    yep..the part the chuck butts up against is actually the end of the bearing...same diameter.
    Apr 2009
    CA USA
    106
    10
    ok , thanks . good to know that a PO didn't hack up the spindle ..
    hope to get back to my chatter / finnish issue . will start a new thread for that
    animal
