richtes
- Aug 25, 2005
- Malvern, PA
Finally got my 644-R on it's stand. The lathe sat for most of the last 50 years, so it's clean, but hadn't moved.
No matter what position the half nut lever is in, I can't move the power feed lever. It should move with the half nut lever down, correct?
Can I get my fingers on whatever I need to play with to get the lock out pin disengaged, if that's what the problem is? I feel the lever clicking against something as when I move it up or down.
Rather not take anything apart if I don't have too. The bull gear pin took a lot of playing, but then moved like it was never stuck.
Rich
Rich
