vicfi
- Oct 5, 2020
- Bucks County
I've read many forums about stuck taper pins but nothing has worked! I ground off the top to make sure it wasn't shroomed on the top. I tried drilling in a little bit on both sides but drilled off the center by accident. No amount of heat, pb blaster, or brute force has got it to move. And yes I am hitting the right side. I've triple-checked that. At this point, I don't know what to do. The worst part is there are many more taper pins to remove. The wicks on this 1945 south bend have probably never been replaced before by the looks of it.
