Abused 13" I picked up
Results 1 to 15 of 15
    May 2012
    Tennessee
    32
    51
    14
    Default Abused 13" I picked up
    I'm going to try and resurrect this one. You cant tell from the pictures but I think it's salvageable
    Paul
    lathe South Bend 13" parts lathe
    Nov 2007
    marysville ohio
    9,458
    2720
    6293
    Looks repairable, did you get the broken off piece for the t / a cross slide extension? Might be new enough that it may have a hard bed.
    May 2012
    Tennessee
    32
    51
    14
    It's all there shy the 5C collet adapter and door for the base. All I've done is a clean up and tear down on the headstock to see just how bad it is. The bed is hardened and cleaned up nicely. As bad as it looks the lathe looks like it didn't have a lot of heavy use. Well, right up till the forklift got a hold of it
    Paul
    Oct 2012
    central Pa., U.S.A.
    326
    132
    75
    Nice score! Hard ways and camlock spindle. Extra qc box? T/A (taper attachment, not torque amplifier) certainly looks fixable with a couple parts that are available. It's well worth your time and the price you paid! Good luck with it. PB
    Jul 2012
    Baltimore, Md.
    1,025
    1149
    532
    I'd buy it in a heartbeat! Also, it looks like the piece brolen off of the taper attachment is in the one box of parts!
    May 2012
    Tennessee
    32
    51
    14
    Thanks. Yes there was a extra gearbox. I had to rob one of the gears in the selector levers from it. Other than that it's intact.
    Paul
    May 2012
    Tennessee
    32
    51
    14
    Yes both parts are there. I'm going to try and clamp it down to a piece of plate and braze it back together. both cross feed and compound screws are broke off on the ends and bent. I'm going to press and pin new ends on them and re-machine them unless I can find some that wont cost as much as I paid for the rest of it Please excuse my messy shop
    Paul
    Aug 2008
    Western Maryland
    355
    30
    6
    Yep, No doubt about it, Great Deal! Easily repairable. At the initial price paid you can easily afford to spend a few dollar$ and have a great machine worth much more the the total investment. Kind of projects many of us enjoy running across.
    Mar 2010
    NW Ohio, USA
    550
    20
    24
    Excellent.... and that looks like it was a tool room lathe.
    Ed S
  10. Likes SpringGunner liked this post
  11. #10
    May 2012
    Tennessee
    32
    51
    14
    A previous owner had tried to remove and re-install the bearing caps without removing the bearing expanders. The front thrust bearing had come apart and no doubt was the original problem trying to be addressed. It sounded pretty bad I made a bronze thrust washer for the rear but before settling on the final specs for it I noticed the back gears and rear drive gear were out of alignment. I had to ad a .135 to the front and .535 to the rear to maintain the original mesh pattern on the gears. I was wondering if anyone else has run into that before? I've never seen it mentioned before.
    Paul
  12. #11
    Mar 2005
    kansas city kansas
    1,309
    21
    14
    I can fix the crossfeed leadscrew. Call or text for a quote nine136366107. Thanks Mike
  13. #12
    May 2012
    Tennessee
    32
    51
    14
    Quote Originally Posted by jayhawkman View Post
    Thanks I appreciate it. I'll probably just make a new one from PH4140. The threads are worn in the middle and the nut is worn slap out. It was full of dirt and grit when I tore it down.
    Paul
  14. #13
    May 2012
    Tennessee
    32
    51
    14
    Finally made some chips tonight. Still a way to go to be complete but it's usable at this point Picked up a used Aloris post on Ebay but it was a different size than what it was listed as. I'll have to cobble together some tool holders. I did one just to be able to fit the chuck to the back plate. I was hoping to be able to use the same size posts on both lathes but it doesn't look like that will happen. I'm running a KB27D VFD to power it. Don't know how I'm going to mount it. It's much larger than I thought it was. Here's some before pictures from the original CL ad and some from tonight.
    Paul
    00x0x_6vbwk5qanxv_600x450.jpg 00w0w_jbyjxrezhst_600x450.jpg 00s0s_hwrvuzrhktg_600x450.jpg
  15. #14
    Dec 2008
    North Carolina
    682
    200
    158
    It looks good Paul. It must be very satisfying.
    Vlad
  16. Likes SpringGunner liked this post
  17. #15
    Oct 2004
    SE Ohio
    907
    137
    from clunker to wonderful! Great job.
  18. Likes SpringGunner liked this post
