AC motor for an old South Bend bench lathe...
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 70
    Mar 2019
    Washington
    33
    17
    Default AC motor for an old South Bend bench lathe...
    Hi folks,
    I'm new to the forum and would welcome some advice!
    I have an old South Bend bench lathe (9 X 30) and the original motor finally gave up the ghost. Is there a shop you can recommend that would be able to rebuild such a motor, (local in Seattle or to ship)? Is it cost effective to do this, or, should I attempt to re-motor it with a newer unit?
    Oh, and yes, I do believe it may have to be rewound (blue smoke and all :-)).
    Thanks in advance,
    CMRantz
    Apr 2012
    Massachusetts
    104
    6
    12
    Just put a new motor on. Its going to cost just about as much to have it worked on, so why bother. A good new Baldor one should only run you about $200 at the most depending on voltage / shaft size etc...
  3. Likes CMRantz liked this post
    May 2017
    Minnesota
    664
    553
    342
    My grandfather's 9" Atlas got a new motor from Northern Hydraulics about 20 years ago for about $100.
  5. Likes CMRantz liked this post
  6. #4
    Mar 2011
    Denver, CO USA
    10,083
    58
    5660
    eBay has easily available variable speed motors for sewing machines.
    Search for servo sewing motors.
  7. Likes CMRantz liked this post
  8. #5
    Apr 2004
    Modesto, CA USA
    6,456
    1037
    That motor should be instant reverse which is nice on a lathe. I would either get it rewound or replace with a 3 phase motor and vfd to retain quick reverse and braking function. If you use a vfd just use the old switch.
    They make vfd's that run off single phase 120 volts up to one horsepower.
    Bill D.
  9. #6
    Oct 2010
    Dewees Texas
    2,166
    26
    562
    Om my 9C I replaced the original motor with a 3 phase motor off an A25 Traub. The Traub motor is actually the feed motor. Instant reverse is handy if you have 3 phase. All it took was a simple bracket and boring out the pulley to fit.
    The base the motor is bolted to had a large selection of holes to choose from so many different motors could have been used.
  10. Likes CMRantz liked this post
  11. #7
    Dec 2010
    Mifflintown, PA 17059
    1,608
    17
    157
    If it was me I would check the price for a new motor then contact a re-winder and get a price to rewind it. Then decide which is better. Usually a re-winder will include new bearings. Rewound motor is as good as new depending upon how good the re-winder is. Ask around to determine if the re-winder does a good job. Those that are re-winding motors for local companies are darn good or would not be doing it very long. If windings are all that is bad with the motor re-winding is cheaper because all the hardware is reused.
  12. Likes CMRantz liked this post
  13. #8
    Sep 2012
    Cincinnati
    149
    27
    Really need nameplate info to give better guidance. I know of one shop that might do you a favor to fix it. Normally they would not touch a motor like that. Fixing or replacing it really depends on what it is.
    Can you post a picture of the nameplate or post all the nameplate data?
  14. #9
    Mar 2019
    Washington
    33
    17
    Bill, I'm not sure how to do this, the switch was missing and years ago my dad just put a plug on the motor as a "switch." A bit dangerous, I know!
  15. #10
    Mar 2019
    Washington
    33
    17
    If I could just find a local shop...
  16. #11
    Mar 2019
    Washington
    33
    17
    Mark, the nameplate of the motor or lathe?
  17. #12
    Mar 2019
    Washington
    33
    17
    Where is a good place to look for motors such as you suggest for retail sale/s?
  18. #13
    May 2012
    Pittsford, NY
    975
    681
    626
    Instant reverse isn't such a good idea on a threaded spindle.
  19. Likes mhajicek liked this post
  20. #14
    Sep 2010
    moscow,ohio
    5,564
    540
    1756
    Tell us what motor you have now and how much you are willing to spend.
  21. #15
    Mar 2010
    Utah
    686
    50
    41
    All motor repair shops sell motors also, new and used. Take your motor in to a repair shop and see what they can do..
  22. Likes CMRantz liked this post
  23. #16
    Mar 2019
    Washington
    33
    17
    I'll pull the motor this weekend and have more info. I have no idea how much a rebuild costs, you'd have to give me a range. I do want to get the machine back up and running again. Looking at the cost of replacement means I have quite a bit of headroom for repair on the original, if it can happen. I'd like to keep the original if possible as everything else on the unit is from the same era.
  24. #17
    Aug 2004
    ventura,ca.usa
    347
    44
    Unfortunately, as with so many other previously rebuildable devices, it is becoming harder and harder to find anyone competent that will perform that function at a reasonable rate. (at least for small motors under 3 HP ) Usually, if you live in or near a good size city with some industry there will be at least one repair/rewind shop,but you will probably find the cost of rewinding is going to be as much as a new motor,or so close as to make it not very cost effective. All in all, its a motor, it is a tool with little sentimental value, as long as you can get one with the same frame size or one that will fit without major modification, buy one and get back to making chips... Jim (oh, just for reference, I am probably overly frugal/cheap myself and tend to search out the best deals as much as possible)
  25. Likes CMRantz liked this post
  26. #18
    Mar 2019
    Washington
    33
    17
    Well sir, here is the motor type and specs...
    General Electric
    Model: 5KC43MG17EX
    HP: 1/4 FR: 56
    V: 115 PH: 1
    RPM: 1140 CODE: M
    Thermal Protection
    A: 5.8 CY: 60
    Temp Rise: 40c SF:1.35
    SER: RSL
    The motor has oil caps over the bearings and instructions for oiling schedules. It also has end caps that have two tabs for the cradle mounts. They clamp over the end caps on the tabs and a screw fastens down the assembly. Trying to fit a new motor to that assembly look to be a PITA. So, I'd like to have this motor repaired, if possible!
    Thanks in advance,
    Craig
  27. #19
    Mar 2019
    Washington
    33
    17
    General Electric
    Model: 5KC43MG17EX
    HP: 1/4 FR: 56
    V: 115 PH: 1
    RPM: 1140 CODE: M
    Thermal Protection
    A: 5.8 CY: 60
    SER: RSL
    Thanks in advance,
    Craig
  28. #20
    Mar 2019
    Washington
    33
    17
    Mark, was that the needed information?
    Thanks in advance!
    Craig
