AC motor for an old South Bend bench lathe... - Page 4
Page 4 of 4 FirstFirst ... 234
Results 61 to 70 of 70
  1. #61
    Mar 2019
    Washington
    33
    17
    I will study it!!!
    Thanks again,
    Craig
  2. #62
    Mar 2019
    Washington
    33
    17
    10K,
    A last question... if I'm cutting mainly wood and plastic do I still need the extra HP? My usage is VERY light, aluminum being the "hardest" material. I don't use it to thread (with all the gear changes and such). It is truly a polisher and "hobby" lathe.
  3. #63
    Sep 2010
    moscow,ohio
    5,757
    559
    1827
    After checking around this would be my choice for a single phase budget motor-
    MTR2-P50-1AB18 | Standard Performance AC Motor: general purpose, 1/2hp (PN# MTR2-P50-1AB18) | AutomationDirect
    it has a good solid warranty backed by a company with a good reputation, will provide all the power you need, and note the bottom feet are removable which should make mounting a bit easier, is TEFC so no worries there...you WILL need a 2" motor pulley!!! That is very important! Otherwise you will be overspeeding the lathe and possibly damage it.
    Here is the pulley- Gates BK20 x 5/8" - you want a 5L belt to go with it.
    Gates - BK20 X 5'/'8 - Motion Industries
    Ps- you might not need that bit of exrta bit of power now, but rest assured you will eventually and it doent really cost more anyway.
  4. #64
    Mar 2019
    Washington
    33
    17
    Thanks 10K!
    Getting the old girl up and running will be fantastic... it's funny, I can go for months w/o needing it, but when I do, well, you know the drill :-)!
    Craig
  5. #65
    Aug 2004
    ventura,ca.usa
    352
    48
    and to add to 10K's recommendation if I might, a larger motor won't work as hard and last longer. Eventually you will use more of your lathe's capability, if you have it you will use it... Jim
  6. #66
    Mar 2019
    Washington
    33
    17
    Quote Originally Posted by jmm03 View Post
    Agreed, and thanks for all of your input. It is much appreciated!
    Craig
  7. #67
    Dec 2013
    Vermont, USA
    446
    6
    107
    I have no idea if the original poster has already found and bought a motor, or even decided firmly on what motor he wants to buy, but I have an original 1/2 HP motor from an approximately late 1950s/ early 1960s SB10K, and this one has a drive exactly like the "9s" and I am not going to be using that motor because I am going to go 3 phase/ VFD.
    The condition when I bought the lathe was little-used though fairly grubby, and I have not run it (and the seller had the wiring apart from a prior move) until I can really pull it down and refresh it from top to bottom. The seller told me that the motor worked and I have no reason to expect it doesn't, and probably has very few hours on it, and I could test it. I don't know if it's worth the trouble to either of us to ship it. Just putting it out there....
  8. #68
    Mar 2019
    Washington
    33
    17
    kd1yt,
    I was away on business and just got back. I'm interested in your motor, is it a 56 series and is it on its cradle? I can use my old cradle if the mounts are the same.
    Thanks for posting this info!
    CR
  9. #69
    Dec 2013
    Vermont, USA
    446
    6
    107
    I've been busy with work and family and just saw your reply. It is a 56 motor and it is on/ in its cradle. Let me try to find some time, although it may be a few days or even next weekend before I can hook it up to confirm that it runs. I am virtually certain that it runs as the whole lathe was little-used and the seller seemed very honest, but I wouldn't want to sell it to you without confirming for my own eyes that it runs- it would be a massive waste of both of our time if it arrived for you and didn't work. Once I confirm that it works, would $75 plus actual shipping seem reasonable? I looked on ebay and South Bend motors are all over the map, although mostly at the nutty-expensive end of the map... I am not looking to take advantage... but I could use the funds for countless other aspects of my lathe project and other projects
  10. #70
    Mar 2019
    Washington
    33
    17
    kd1yt,
    That is more than fair... if it works just let me know. My email is: [email protected]
    That's easier than always logging into the forum.
    Craig
