I wasn't sure if the collective likes more specific threads to comb through or not so I didn't add this into the recent great threads about Aloris stuff. I took the bait on the recent Aloris discussions and got myself setup with a CXA for my 16" lathe. Even Aloris themselves recommends the CXA for a 16". Got me thinking that the dimensions between center and top of saddle must have changed significantly between the 40's and now.
Here is a shot of the Aloris catalog where they break down all makes of lathes and the products that go with them. (pg 29 of the Aloris catalog)
The CXA is definitely not the right unit for my lathe (without a riser) as the tool holders are outside of their adjustment ranges on the toolpost and not supported well. I bought a CXA #5 (MT3 Taper) holder and have it installed here. A damn fine tool for my collection of MT3 drills!
Here it is in the tool post and centered to drill the hole beyond in the chuck. You can see that it sits above the tool post and the adjustment nuts are floating above the top and not doing anything.
This required some MacGyvering!! I made a plate out of 5/16 Aluminum plate.
3/8 would be even better but I dont have this kind of material around. If anyone gets around to making quality riser blocks for Aloris Toolposts I am interested. I am surprised that Aloris doesn't seem to make these that I can tell. They could sell them with a slightly longer bolt. hint hint...
Anyway the result is shown here with a cutter on center line with some repeatability since the adjuster knob is resting on the toolpost.
