Domodude17
- Aug 14, 2017
I'm debating removing the compound on my 9A and replacing it with a riser block. I've heard it improves rigidity and finishes, and I don't really use the compound much at all. How do you feel about the change?
Other reason i'm asking is because if I do decide to remove it, I need to buy a block of metal no matter what. I know cast iron somewhat has vibration dampening properties, but i'm not sure i'd be better off with that or just a block of steel. Not sure if it'd even make a difference? Thoughts?
