New-to-me South Bend lathe. I can't seem to get the sliding gear to slide.
I can't quite tell, there may be a collar over the shaft effectively locking out the middle gear (blue arrow). I also don't have a handle on it. I'm guessing a previous owner locked it out as such.
There is a nut on the inside of the banjo, and the outside end has two holes. What is the purpose of those holes? Do I need some kind of spanner to remove it, or is it safe to undo the nut on the other end? I presume its just a shaft, just making sure before I break something.
thanks,
philip
thanks,
philip
