Apron Parts for Catalog 744A 9A Lathe
Likes Likes:  0
Results 1 to 7 of 7
    Sep 2019
    Wisconsin
    8
    Default Apron Parts for Catalog 744A 9A Lathe
    The lathe I picked up last month has a broken wheel assembly. The handwheel is intact but it's missing the taper pin and until I start disassembling it, I'm not sure what part I need.
    Looking at the parts list from form 902C from 6-15-57, I'm guessing I either need PT204NK2 (part of the AS76NK1 assembly)or AS228NK2. Interestingly enough, Grizzly's South Bend parts store has the AS76NK1 in stock for $149.00 although eBay appears cheaper at least for this item.
    Are there any other sources that might have this part that I am overlooking?
    --Joel
    Sep 2010
    moscow,ohio
    6,112
    600
    1976
    isnt that for the whole handwheel? those are assembly numbers, meaning more than one part,,in that case the wheel casting with the little handle pressed in.
    you can buy taper pins at most ace hardware srores.
    Sep 2019
    Wisconsin
    8
    Unless I'm misreading the exploded parts diagram, the assembly includes the gear and the shaft. The shaft has its own part number but was only sold with the full assembly. I assume it was held in place to the wheel with the taper pin.
    Sep 2010
    moscow,ohio
    6,112
    600
    1976
    i cant recall, but if you are only lacking the taper pin, its a 1 dollar part.
    Oct 2015
    Virginia
    569
    19
    132
    Yeah, post up the approximate dimensions of the taper pin you need and PM me your address and I'll send you one if I have one.
    Sep 2019
    Wisconsin
    8
    Quote Originally Posted by iwananew10K View Post
    I wish it was just the taper pin, see the photos.
    Sep 2010
    moscow,ohio
    6,112
    600
    1976
    yes, thats a different matter, it can be repaired but replacemnt might be your best option depending.
