Attempting an idler gear broken tooth repair.
Results 1 to 9 of 9
    May 2019
    CANADA
    Ontario
    36
    22
    Default Attempting an idler gear broken tooth repair.
    Of the few parts that required replacing on my recent SB 13 rebuild (aside from a blown capacitor on the motor), only one part was actually broken, a missing tooth on the idler gear. All other replacements were from wear. A search for a replacement idler, here and on theBay, turned up nothing, so a DIY repair was necessary. A single tooth was salvaged from an old damaged Bull gear, carefully cut and sized to fit snugly into a matching slot in the idler. A small copper shim was inserted on one side to properly space the "implant" and prevent it from moving during the brazing process. A friend did the actual brazing. After cooling, the area was cleaned up using an angle grinder and file to restore the proper shape, a light buff with a wire wheel took off any sharp edges. During a brief test run, a very mild "thud" was heard, a quick tweak with a file corrected that. I'm very pleased with the results, wouldn't hesitate to do it again if necessary.
    Hope this encourages someone to give it a shot.
    Raydel
    Attached Thumbnails Attached Thumbnails 20200728-img_20200728_105329.jpg   20200728-img_20200728_105259.jpg   20200728-img_20200728_105157.jpg   20200730-img_20200730_182216.jpg   20200730-img_20200730_182858.jpg
    Apr 2018
    6,125
    2934
    Quote Originally Posted by Raydel View Post
    Nice job but how come you didn't just get one out of the Boston Gear catalog ? Price too high ?
    Jul 2010
    Virginia, USA
    3,564
    87
    690
    Because it is 14DP and Boston does not make them?
  4. Likes Rudd liked this post
    Apr 2018
    6,125
    2934
    Quote Originally Posted by kitno455 View Post
    That answers that question, thanks Good thing I have a 14dp shaper cutter ...
    Coulda sworn someone did tho ... Browning ?
    Jul 2004
    Houston, TX USA
    31,521
    Similar - looks like yours is the better idea - and certainly for non restricted inner details versions - like not much "wall" thickness
    * Fix L&S Crossfeed Clutch Gear
    have fun
    Jun 2013
    New York
    649
    433
    375
    Wow that's beautiful workmanship! Thanks for sharing! I'll have to file that one away in the "bag of tricks"....
    Apr 2020
    Ohio
    654
    592
    199
    Quote Originally Posted by pavt View Post
    I would file it in the same bag if only I had to skill to do it! This trick would be a way to make a damaged gear a destroyed gear in my hands. Good job it looks great
  9. #8
    Oct 2016
    Indiana
    53
    7
    Great job on the repair. Most of the time, I have seen people just braze up the void, and then re-cut on a dividing head.
  10. #9
    Nov 2013
    Eastern Massachusetts, USA
    6,347
    5622
    5980
    Nicely done, neat repair. Thanks for sharing.
    PS: Don't throw out that "donor" gear. Other PM members may need tooth transplants also.
