torker
Cast Iron
- Dec 3, 2003
- British Columbia
I have to drill a bunch of 3/4" holes-1 3/4" through 1 1/4" plugs, CRS. With all the heavy work I decided to grease the backgear spindle before I went any further. I drilled two holes and all was fine. Went out to the shop this morning and now the back gear keeps popping out. I see some set screws under the shaft at the rear. Do these need to be adjusted now or did I pump in too much grease or....what the heck did I do here. Thanks.
Russ
Russ
