Back GearAdjustment - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    Jan 2019
    Hawaii
    737
    324
    205
    Wow! Much improved. I am not much of a video person so I can't relate the incredible improvement but I was beating my lathe up with that old back gear assy. Now I am running quiet and I have new spindle speeds at my disposal! Teds part was different in a few ways from mine which leads me to believe the shaft on mine was also bespoke. There was no chamfer on the hole at each end and mine was not stamped "Grease". The tolerance between the two shaft gears is much tighter too so that I had to position the new assy between the spindle gear shoulders with about .02 to spare! Worst part is that the old grease-port plug doesn't fit in the new one so I'll have to make something there!
    Having a functional lathe sure is useful for part clean up!
    I like seeing the spokes in there!
    Once again it is proven that with an old South Bend Lathe there is no problem that cannot be solved with some ingenuity and/or an open wallet!
  2. Likes texasgunsmith, MetalCarnage liked this post
  3. #22
    Feb 2015
    Florida
    877
    248
    Even though it is marked "GREASE", I would still put in "OIL" (Type C), because the "GREASE" is no longer available and there are NO KNOWN SUBSTITUTES.
  4. #23
    Jan 2019
    Hawaii
    737
    324
    205
    I made a cap/plug today. If I had a smaller set of stamps I could stamp "OIL" on this!
  5. #24
    Feb 2015
    Florida
    877
    248
    Quote Originally Posted by Kevin T View Post
    Your knurls are looking a lot better than before,
  6. #25
    Jan 2019
    Hawaii
    737
    324
    205
    Quote Originally Posted by SLK001 View Post
    Thanks! I was feeling good about that last one. It helped a bunch to be able to use the new back gears to make it! 80 RPM felt right for the 3/4 diameter material.
