Baldor Motor / Furnas R44 Wiring Help
Likes Likes:  0
Results 1 to 5 of 5
    Nov 2008
    Easton, PA
    2,001
    43
    210
    Default Baldor Motor / Furnas R44 Wiring Help
    I read a good post where OldMachinist was very helpful in providing a wiring diagram for a motor being wired to a Furnas R44 drum switch.
    My motor seems to have the same wire-colors, and in the same configuration. I provided the diagram on my motor.
    I just wanted to confirm that OldMachinist's diagram will be compatible with my motor as well?
    The first picture is from the original post where OldMachininst helped out.
    Second picture is MY motor's diagram.
    Then, comes my switch and inside diagrams.
    Attached Thumbnails Attached Thumbnails motor.jpg   photo-1.jpg   photo-3.jpg   photo-4.jpg
    Nov 2008
    Easton, PA
    2,001
    43
    210
    Bump.. Anyone?
    Feb 2007
    Philly, Pa.
    362
    59
    32
    Brad,
    Pinniongear provided several diagrams in the thread "High school students need help wiring.." dated Nov 2,2011.
    I did not compare them to your setup but I was able to wire up my GE and Square D switch using diagram No 8.
    RF
    Mar 2010
    Nashville, IL USA
    345
    21
    It will work. There are Nema standards for motor wiring numbers/colors and your motor complies. Here's the standard.
    Jan 2011
    South Jersey, USA
    37
    7
    Brad,
    I sketched out the wiring diagram for you. Not any cryptic electrician's diagram, but a sketch of the actual wires and how to attach them. Electricity for the non-electrical hobbyist, if you will. I can not post a picture, but I can scan it as a PDF file and email it directly to you. You can post it if you think it could help others muddle through wire schematics. Send me a PM with your email and I'll get it on its way.
    PS- Didn't I draw this up for you at a SBL users meet up near Reading? I thought it was you.
    MD
