kg6bws
- May 28, 2013
- Santa Clarita, Ca
I posted this on another forum as well, in an effort to get as quick an answer as possible Im posting here as well.
Hey all. I have a light 10 that I got a few months ago. Ive been using it plenty, works wonderfully, but the last couple times Ive noticed the bearings are warming up. Its a (I was told) 1958 CL670Z with bronze bearings. Measured play on the spindle is .003 on the rear bearing (yes I know I need to tighten that up) and .001 on the front bearing. Everything Ive been able to find says that with the bronze bearings that .001 is good. Is that correct or am I doing something wrong?
First question - Have any of you measured the temp of your headstock bearings with a temp gun? If so, what are your typical temperatures? I didnt check until they started feeling warm and Im coming up with generally about 112 or so, a few degrees less on the rear bearing. Today however, the whole lathe started slowing down (almost bogging down) but the belt wasnt slipping and when I measured the temp it was 124F. I shut it off at that point. I should probably mention that I was running the highest speed with the lower jackshaft belt setting (not sure of the exact rpm).
Second - Ive done plenty of searching but it seems that everyone that asks about spindle removal gets the same answer "Its been discussed before, search". No offense meant but unless its on page 500 of Google, I cant find one. I have been able to piece together what I think is the proper procedure. If Im understanding correctly, I tighten the 2 screws in the bearing cap to loosen the expander. After that, and removing the rear nut, I should be able to lightly tap the spindle out? Correct?
I also just thought of something. When I measured the play in the spindle, I pushed down on it to zero the indicator and the needle didnt move at all. When I lifted on it the needle came up .001, maybe a hair over but not quite to .0015. Am I missing something here?
I have a kit coming with new wicks and wipers so I want to pull the spindle anyways so I can replace them. Any advice here or pointing me towards a good writeup is much appreciated. All the removal pdfs Ive found deal with the cast iron integral bearings, but mine looks different from every picture Ive found. THanks much.
Edit - I cant find any of the headstock drain holes Ive seen mention of. Im guessing with mine just pull the cups out and let it drain that way? Thanks.
