thenrie
- Jan 22, 2011
- Stafford, VA
Posting here in the SB forum, because I'm going to have to make a new overarm to adapt a Porter Cable milling head to my Burke #4 horizontal mill, and I'm going to be doing it on my SB9A. There is no Porter Cable forum and no Burke forum, and this seems to be the forum to go to for answers and opinions. So here goes.
I need to make a new overarm shaft to adapt my Porter Cable Mark II vertical milling head to my Burke #4 horizontal mill. Finished dimensions will be 2" diameter, about 16" long and will need to be bored for the milling head's 5/8" drive shaft and bearings.
Question is, would it be better to make this shaft from mild steel, cast iron, or something else. The mild steel would be easier to machine on my SB9, but what about vibration and stability for milling with the vert head? Would cast iron be better? Cost is about the same. Other options?
I'm also going to have to extend the 5/8" drive shaft, but I'll cross that bridge when I get there.
