I've recently rebuilt a 1941 SB 10R, a beautiful machine. However I've not yet been able to make chips due to motor issues. It cam with a Century 1/2 hp in a 66 frame. Basically I need the expertise of someone knowledgeable with these older motors. There are various reasons I'm going this rout rather than outright buying a new motor. Some of the reasons are money, mounting plates, brackets and I'd also like to keep it as original as possible.
My problem is with the centrifugal switch, "inside the motor" and the contact points. Below I've posted the best pictures I can manage. Apparently one of the contact points has blown off and I'd like to either locate a replacement switch or affix a new or replacement contact point where the old one was. Any help with getting this motor operational is appreciated.
Thank You!
PS The first photo is a wide shot of the inside of the motor and switch and board.
the second is just a tighter shot.
Third is a close shot of the switch where I've parted the contact points with a pick.
Finally, this picture shows the board where the missing contact point gos.
Thank You!
