Change gear setups
Likes Likes:  0
Results 1 to 7 of 7
    Sep 2017
    Florida
    Default Change gear setups
    I just finished restoring a 9" SB and was trying to setup to cut some threads but the diagram does not make sense or work. Fig.2 shows the 80t connecting the spur gear and the screw gear but that is impossible as they do not line up. They are not on the same plane.... I have literally found zero explanation on setting up change gears online. I cant be the only one with this issue. As I can tell you have to use all three of the change gears, u cant just use 2 as Fig. 2 suggests. Im trying to setup for 24 or 26tpi.
    Sep 2010
    moscow,ohio
    5,869
    578
    1874
    A pic will help...could be a couple things.
    Jan 2019
    District of Columbia
    32
    Which model
    Sent from my SM-G975U using Tapatalk
    Jan 2019
    32
    Or
    Sep 2010
    moscow,ohio
    5,869
    578
    1874
    no difference between model B or C when it comes to threads, only the feeds are different as the model C has no apron reductions.
    I know pics can sometimes be a problem, if you can answer one question 99% sure the issue can be diagnosed even without pics.
    Q- which interface does not line up? (screw gear to 80T or stud gear to 80T)
    Sep 2017
    Florida
    I figured it out. The issue was the spacer on the screw gear that allows u to jockey it side to side one gear width. Just need to move that for 2 gear setups.
    Jul 2004
    Houston, TX USA
    29,190
    Quote Originally Posted by kitecop View Post
    Its so you can accommodate compound gearing - which is invariably TWO PLANES
