Change gear setups
kitecop
Sep 14, 2017
I just finished restoring a 9" SB and was trying to setup to cut some threads but the diagram does not make sense or work. Fig.2 shows the 80t connecting the spur gear and the screw gear but that is impossible as they do not line up. They are not on the same plane.... I have literally found zero explanation on setting up change gears online. I cant be the only one with this issue. As I can tell you have to use all three of the change gears, u cant just use 2 as Fig. 2 suggests. Im trying to setup for 24 or 26tpi.
Which model
Sent from my SM-G975U using Tapatalk
no difference between model B or C when it comes to threads, only the feeds are different as the model C has no apron reductions.
I know pics can sometimes be a problem, if you can answer one question 99% sure the issue can be diagnosed even without pics.
Q- which interface does not line up? (screw gear to 80T or stud gear to 80T)
I figured it out. The issue was the spacer on the screw gear that allows u to jockey it side to side one gear width. Just need to move that for 2 gear setups.
