change gears for series O 11 inch?
reddogforge
Oct 15, 2017
Is there any compatability among other sb lathes? My series and size ( 1928) seems to be fairly rare, if not could someone help me with the specs so i can cut my own? Heck it would be a great project for my new indexing head :)
Thanks!
Shane
You can tell us and yourself what you have
Any change gear known to be for your lathe you do have can be measured
Count teeth
Add two to the count
Measure OD with mic
Divide that O.D. in to the count plus two
Example:
32 teeth, 2.125" O.D.
34 divided by 2.125 = 16 diametral pitch - often written 16 DP
I have an 11” 1922 27-B that I’m in need of some gears also. Are you looking for certain ones or all of them? I know that mine have an ID bore of .625 and keyway is .19 wide. Thickness is also .625 but that is as far as I’ve gotten on figuring things out.
