change gears for series O 11 inch?
Likes Likes:  0
Results 1 to 4 of 4
    Oct 2017
    16
    Default change gears for series O 11 inch?
    Is there any compatability among other sb lathes? My series and size ( 1928) seems to be fairly rare, if not could someone help me with the specs so i can cut my own? Heck it would be a great project for my new indexing head
    Thanks!
    Shane
    Jul 2004
    Houston, TX USA
    30,227
    You can tell us and yourself what you have
    Any change gear known to be for your lathe you do have can be measured
    Count teeth
    Add two to the count
    Measure OD with mic
    Divide that O.D. in to the count plus two
    Example:
    32 teeth, 2.125" O.D.
    34 divided by 2.125 = 16 diametral pitch - often written 16 DP
    Sep 2019
    Washington
    I have an 11” 1922 27-B that I’m in need of some gears also. Are you looking for certain ones or all of them? I know that mine have an ID bore of .625 and keyway is .19 wide. Thickness is also .625 but that is as far as I’ve gotten on figuring things out.
    Jul 2003
    savannah, jaw-ja
    1,755
    1234
    421
    Keyway is more likely .1875" wide, or at least started life as such.
