Yabut... How hard is it to find the
rest of the Industrial Sewing Machine it runs?
IF.. I had a SB lathe to power - say 9" or 10"?
- Wherein a 3/4 HP 3-Phase single speed is the sweet-spot so long as all belted and geared ratios remain
- AND for variable-speed one can simply DOUBLE rated HP to cover drop-off at low RPM for VFD'ed AC or at high RPM for DC on DC Drive,
- AND VFD have already been "done to death" and not my rice bowl anyway, even if I DID eat rice..
- THEN, for smooth, sweet, "mini-10EE" running, I would use a KB-Penta 240D 4Q regenerative DC Drive in the neat and handy NEMA 4X housing:
KBRC-240DBLACK - KB Electronics - DC Drives | Galco Industrial Electronics
and
- a motor such as the 1.5 HP Reliance RPM III Stabilized Shunt 180 VDC model of this sort:
RELIANCE 1.5 HP RPM III DC MOTOR, 1750 RPM, FR-XC1811ATY, 180 VOLT | eBay
Take note that the Reliance motor is 280 lbs Avoir on pallet, the sewing machine motor 15 lbs.-minus in cardboard box.
All muscle, that greater mass. Torque. Not fat. Just look at the shaft diameter.
Sewing machine motor might not be such a bad idea after all, given the chronic Iron Deficiency Anaemia South Bend's have in their Levi's.
Genes, that is.
Might want to find a "relieving attachment", too. Sewing machines are notorious for their incessant "self fornicating" motion.
Kidding aside?
You'd want only a 1/2 HP RPM III 180 VDC shunt motor for an SB.
I'm not sure enough were made in that low a HP to be able to find one, though.
