I have an interest in some face plate work and I have a couple South Bend face plates to go along with my lathe but no way to safely clamp work. I know I need 5/8 thru bolts and T-nuts. Is this a place where imported tooling is not an issue? I can't see myself clamping anything to the faceplace that is more than about 3 inches high and all the sets I am seeing include a lot of taller clamp blocks and bolts I would imagine they are more specific to a Vertical Mill. You guys have any wisdom to impart here? Is there a type that is better suited to lathe operations? I am thinking lower profile is important.
I am working on a brass riser for my toolpost and I went to the hardware store to MacGyver something to get me by. Ended up with some Grade 8 flange bolts and hardened washers I have a few other projects in mind and am going to need something better in the future.
