compound tee nut
Results 1 to 7 of 7
    Nov 2018
    AUSTRALIA
    Default compound tee nut
    So the only way i can make a tee nut for my new AXA QCTP is to turn a round one?
    i read i can make a rectangular one in the 4 jaw chuck but i cant picture how to do the stepped side cut outs...
    Maybe i could turn an over sized round one then use the 4 jaw to trim it back to rectangular shape (with round ends)
    Mark
    Complete Novice
    1935 9in model B Workshop
    May 2012
    Indiana
    991
    181
    356
    Size the blank in the 4 jaw chuck as you say. Make it the t- slot width x length equal the axa body width. Take the blank and turn the upper part of the t-nut round with diameter just small enough for the t-nut to slide into the slot. Turn the round portion in the 4-jaw so you are cutting the t-nut height. It will work fine.
    T-nuts are typically a milling job and the easiest way in a mill results in that common t-nut shape. Making a t-nut in the lathe results in the round portion because it is just easier that way. As you gain experience you will find the type of machine can have influence on the final part shape, nothing wrong with that as long as it works.
  3. Likes Ralph63 liked this post
    Jul 2010
    Virginia, USA
    3,465
    87
    642
    Hacksaw and a file, done in a few minutes.
    allan
  5. Likes Ralph63 liked this post
  6. #4
    Feb 2004
    peekskill, NY
    24,473
    4574
    Quote Originally Posted by kitno455 View Post
    allan
    That works. Another point: if you turn the large diameter oversize you can square the sides by
    putting the part into the four jaw chuck, sideways. This allows you to square off the side of the
    larger diameter on one side. Flip it around and then you need to set it in the chuck so the newly
    formed flat side is parallel to the chuck face. Often a six inch scale can be used as an improvised
    thin parallel for this.
    Remove parallel before starting spindle...
    This is a fussy job but will do what you want, a T nut that won't spin when you tighten the
    toolpost. Fussy jobs are what happens when you want to get something done and don't have
    a) a milling machine or
    b) a lathe milling attachment.
    Fussy jobs are good for learning technique.
  7. Likes Ralph63, packrat2 liked this post
  8. #5
    Feb 2015
    Florida
    402
    77
    I did mine with an angle grinder with a metal cutoff blade to remove most of the negative metal, then used a flap disk in the same grinder to smooth out most of the cut marks, then a file for the final touches.
  9. Likes Ralph63 liked this post
  10. #6
    Nov 2018
    AUSTRALIA
    Quote Originally Posted by jim rozen View Post
    That made me laugh.
    Thanks to you all i get it now, ill end up with a rectangular tee nut but the upper raised portion will be round same dia as upper portion of compound slide slot.
    Thanks guys
  11. #7
    Feb 2004
    peekskill, NY
    24,473
    4574
    [QUOTE=Ralph63;3447206]That made me laugh.
    You do understand, mine was the voice of experience, hard learned!
    Rule two is, never stand inline with the spindle when starting it up.
