Justmillinaround
- May 4, 2021
Hey folks, I'm new around here and this is actually my first post. I have recently picked up an old South Bend lathe and have been doing my homework trying to figure out what exactly it is. Here is the run down of what I know so far...
I ordered the serial card from Grizzly and it really didn't do anything but raise more questions. The serial card from Grizzly shows a build date of 4/2/1951. The serial number stamped in the bed is "2222TKX" but the card sent to me by Grizzly shows "2222TKL9" with a catalog number of CL8145B. When looking at the serial number decoder, the "X" indicates some "special" features. The serial card tells me that it is a 13" swing x 5' bed, however the physical measurement of the bed shows me that it is a 4' bed, which wasn't a standard option for a 13" tool room lathe in '51. Furthermore, the head stock looks to be of an earlier generation, say pre 1940, when they had the oil cups on top of the spindle bearing caps? I have confirmed that it does have 2 piece, I am thinking bronze, spindle bearings. The spindle thread I believe is the 1 7/8"-8, which also dates the headstock pre 1950 I think. The quick change gear box also has only 1 lever, but I believe by 1950 they had changed to a 2 lever style quick change gearbox. The gearing for spindle speeds also appears to be non-standard based on any catalog around this time that I can find. Maybe this thing was built as a custom ordered piece with a short bed, and specific spindle speeds needed and they put something together with an older gearbox and headstock to accommodate? I am hoping that someone here will have some insight as to what I actually have.
Here is a link to an album with several pics I took of the lathe before removing it from the shop where I picked it up, and the serial card.
TIA for any help.
TIA for any help.
