Current recommended modern oils for South Bend model A
Likes Likes:  0
Results 1 to 4 of 4
    Aug 2013
    Mesa Arizona
    35
    Default Current recommended modern oils for South Bend model A
    Could someone who has successfully used the modern oils on their South Bend Model A tell me the modern equivalents of the A,B,C,and D oils.
    The original recommended oils are just to hard to find and expensive plus shipping.
    With all the new technology in oils I should think some should be even better than oils that were used over seventy years ago.
    Mr Chips
    Aug 2004
    ventura,ca.usa
    525
    136
    The stickys are a wealth of knowledge: South Bend Recommended Lubricants Most of the lubricants listed are fairly easy to find, although not in smaller than 1 gallon sizes sometimes. Hope this helps. Jim
    Feb 2016
    1,736
    1181
    630
    I wrote something up a while ago here:
    Need some encouragement
    A line I find pretty funny from a well respected guy, Forrest Addy, and machine rebuilder here:
    What is the difference between Mobil DTE Light and Mobile DTE 24?
    With something like model A or O spindle bearings, I'd probably use DTE light or ATF for spindle bearings. And DTE heavy/medium on everything else, using two oils instead of four.
    Jun 2013
    New York
    806
    549
    439
    I use Mobil Velocite #10 for the spindle. Mobil DTE Heavy medium for everything else. And Mobil Vactra #2 for the ways. The way I learned it, these are all modern equivalents to the original South Bend oils. Mobil probably improved the oil a bit in the last 70 yrs.
