Cut-off blades for old Armstrong holder?
Results 1 to 16 of 16
    Oct 2019
    URUGUAY
    11
    15
    Question Cut-off blades for old Armstrong holder?
    Hi.I bought some 5/8 x 3/32 cut-off blades but they don't fit in my holder.
    They are square on the edges and it seems that the holder need blades cut at an angle.
    Where can I get those blades?
    May 2020
    Minnesota
    415
    170
    166
    The old Mo-Max bits I've seen from the Cleveland Twist Drill Company had the tapered-bottom style if I'm not mistaken. Not sure where to find modern replacements. McMaster sells bits with a tapered *body*... not sure about the tapered bottom though. Crucible (Rex 95, etc.) and Armstrong stuff might also work since those were contemporary.
    Let me double check... see if I can get a picture.
  3. Likes pchp liked this post
    Feb 2015
    Florida
    1,079
    322
    Who sells cut-off blades that aren't tapered (or some other kind of side relief)?
  5. Likes trevj liked this post
  6. #4
    Oct 2019
    URUGUAY
    11
    15
    Quote Originally Posted by SLK001 View Post
    The ones I buy are Chinese and they are rectangular
  7. #5
    May 2005
    Interior British Columbia
    2,746
    315
    924
    Ayup. Those are tool blanks not parting blades. I suppose, 'a tool blank to make a parting blade from', might be accurate.
    All is not lost, however. Play around with a protractor and see what angle you need. Gonna be between 3 and 7 degrees. Play with the rest on a bench grinder to get pretty darn close to that, and dress down one side.
    I found a set of Vice-Grips and using them to clamp another tool bit, on to the rest of the grinder allowed a fella to keep a pretty steady and even grind on.
    Flip the tool blank around, adjust the clamped down tool bit a bit closer to the wheel, and do the other edge.
    I have done this with cut off blades that were too wide to fit my holders, plus for some holders I made. Worked well.
    As I recall, I set the clamped guide at an angle so as I fed the tool blank across the rest, it only really ground on the edge of the wheel face. You can tap the clamped guide with a chunk of bar, and creep it in a wee bit closer at a time between passes, and you get a pretty nice, straight edge, with a bevel.
    If you are going to err on the angle, make it so the blade squeezes in towards the holder, rather than wedging a sharp edge into it and reducing the stiffness.
    You will still have to grind some side relief on the parting blades, but you will at least, get to use what you bought, if only after a little rework.
  8. Likes pchp liked this post
  9. #6
    Oct 2019
    URUGUAY
    11
    15
    I found something on eBay but I don't know it will work:
    Armstrong 86-259 HSS Cut-Off Blade, M-2 USA 781412862591 | eBay
    And this other which claims to work with old holders but is a bit expensive:
    Ground Bevel Cut off Blades 5/64 3/32 1/8 3/16 Widths M-34 Armstong Williams Style ID 3110
  10. #7
    Oct 2019
    URUGUAY
    11
    15
    Quote Originally Posted by trevj View Post
    Thanks. I am going to try
  11. #8
    May 2020
    Minnesota
    415
    170
    166
    Worth noting that not all tool steels are created equal.
    I've found that the metallurgy of Chinese "tool steels" is generally sub-par to that of American and European made stuff. Bear this in mind if you find that you're having difficulty maintaining a sharp cutting edge.
  12. #9
    Sep 2005
    Northern California
    1,100
    181
    If what you have is what I think it is, those are not parting blades they are Armstrong facing blades and pretty obscure.
  13. #10
    Nov 2004
    So Calif
    265
    14
    If you holder is a Armstrong No. 20 I have some new old stock Armstrong blades for it. See pics attached ( I hope )
    Shipping may be costly though. The drawing is an exaggerated view of the profile looking from the non cutting end. If your holder is a different model I may have the correct blades as well as I have about 30 lbs. of unused old HSS parting blades. Sam
  14. Likes Just a Sparky, pchp, mcload liked this post
  15. #11
    May 2020
    Minnesota
    415
    170
    166
    Quote Originally Posted by samo View Post
    I don't mean to hijack - but just out of curiosity would you happen to have any in 1" x 1/8" size?
  16. #12
    Oct 2019
    URUGUAY
    11
    15
    Yes, I have an Armstrong No. 20. That is what I was looking for. I send you a private message
  17. #13
    Jun 2004
    718
    643
    151
    Quote Originally Posted by pchp View Post
    uruguay that's funny a guy i work with is from there a Rubin Gomez hell of a nice guy
  18. #14
    Oct 2019
    URUGUAY
    11
    15
    Quote Originally Posted by 1yesca View Post
    We are kind people
  19. #15
    Nov 2007
    605
    250
    167
    Default Armstrong 2020R Cutoff Tools
    Although late (again) to the thread, thought I'd add some pics of the much aligned Armstrong tool(s) in my possession.
    These are Armstrong #2020-R and hold a blade that tapers from 0.1 to 0.065.
    Pretty sure these were ground by my pops back in the 60's and I really haven't had a reason to grind any new ones as these
    work fine with an occasional sharpening before using. The finish between the two are noticeable. Perhaps one is a knockoff
    or the line worker was having a bad day. Cheers.
    PMc
    rmstrong-cutoff-2020r-2.jpg armstrong-cutoff-2020r-1.jpg armstrong-cutoff-cropped.jpg armstrong-tools.jpg
  20. Likes pchp liked this post
  21. #16
    Nov 2004
    So Calif
    265
    14
    Quote Originally Posted by Just a Sparky View Post
    1/8" is usually for 7/8" blades at least that is what my old Armstrong catalog says. I have 1" X 3/16" in a couple varieties such as Latrobe Double Six M-2 that are ground finish and are ground for old style RH Or straight tool holders but work fine in my CA Aloris style holder, the actual height is a little over 15/16" and 8" Long. Have Armstrong in the same dimension but 6" L, they look like the smaller ones in the photo I posted and are a black finish and are for RH or ST holders as well. Also have Clarite By Columbia Tool Steel Co. HSS that is 1" X 3/16" with a black finish, these have more of a flat profile on the top and bottom and not specifically for a RH or LH holder. $10.00 each if you purchase more than one plus shipping, can post photos later if needed. These are all old unused condition with a few stains from storage. Sam
